Old 09-Jun-2013, 18:43
Steve Steve is offline
Angry Stand broke on 748
The bracket that holds the stand to the engine bloody snapped in half - result broken top fairing, broken bottom fairing, scratched mirror casing. Any one know where I can get these bits? Especially need the stand bracket and bolt quickly. Also where can I get fairings from
Old 10-Jun-2013, 10:34
Give Nelly a call at Cornerspeed.co.uk as he will tell you if they are still available new.
Otherwise it'll be a trawl through ebay!
Old 10-Jun-2013, 21:06
i will thanks, been quoted ninety quid so far
Old 11-Jun-2013, 09:32
ChrisBushell's Avatar
Mood: Im Going to Italy soon!
Steve,
I think I may have a spare one in the garage from a 996/998 which I think is the same. Drop me a PM with your mobile number and I will give you a call.
Old 12-Jun-2013, 13:56
hawkati's Avatar
hawkati hawkati is offline
Bikes: ducati 996, hawkati, kawacati
Mood: generally vile and mischevious
...and, strangely enough, i have the same problem. Originally my sidestand bracket broke, causing one of the bolts to break in the engine casing. I replaced the sidestand bracket, but it weas worn - this meant the stand leant forward too much, so the bike's leaning over further than the tower of Pisa and it's only a matter of time before that brackret/bolt/everything else breaks.
Would anyone have a 996 sidestand bracket that's either new or s/h unworn? cheers in advance, jamess
Old 12-Jun-2013, 19:56
Speak with Chris Bushall he has a contact
Old 21-Jun-2013, 09:21
Stealth's Avatar
Stealth Stealth is offline
Bikes: 998R, Panigale S
Thanks to this thread I looked at the 998 side stand and noticed how much more the bike leaned than my Panigale sat next to it. A bit more inspection showed that wear is the problem. So hopefully caught in time as the idea of the bike smashing down on its carbon fairings wont do at all!
So thanks for the alert!
Old 21-Jun-2013, 17:23
Plan to check our 998's tomorrow after this!
Old 21-Jun-2013, 18:49
Both my 998s and my 996 are now fitted with stands from either a 749 or 999. For these to fit you need the left lower fairing with the bigger opening for the stand as found on most of the 748/996/998 models that came with a side stand switch.
Old 23-Jun-2013, 21:51
hawkati's Avatar
Cheers for answers - i'll be popping over t oonyerbike in the next couple of days since my brother lives nearby, but if they're extortionate i'll try pro twins! Bike's impossible to put on stand now, so it's a wall-leaner if i'm stopping anywhere!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:49.
