Old 17-Jun-2013, 11:11
DAVEST205 DAVEST205 is offline
Gauging Interest - Ducati 996 Parts
Unfortunately due to lack of time and use i've decided to sell my 996, beforehand there's a few parts to be removed from the bike andreturn to standard condition, gauging interest at the moment but if most of thebelow are wanted il go ahead, i know some of the prices are at the upper end ofthe scale but then this reflects there condition, but i am open to sensibleoffers, pictures to follow:
Termignoni 45mm exhausts in excellent condition - £350 or £300 plus standard exhausts.
Ducati Corse Rearsets and gear/brake pedals in excellent condition (originally purchasedfrom Tom i, so not cheap copies) - £200 or £150 plus standard rearsests/pedals.
Ohlins Rear Shock and spring in excellent condition - £350 or £275 plus standard shock.
Ohlins Road & Track (R&T) FG43 Forks with removable caliper mounts and in excellent condition (comes with bottom yoke which has been powdercoated black and with 65mm caliper spacing) - £1,100 or £950 plus standard forks and lower yoke.
Carbon Air Intakes in excellent condition (CM Composit with filter runners/airboxclips/indicator mounts) - £275 or £235 plus standard intakes.
Carbon Front Fender in good used condition (Ducati Performance) £150 or £120 plus standard fender (red).
Carbon HeatShield in good used condition (CM Composit) - £50 or £40 plus standard heatshield.
Carbon HeelPlates (Corse Type) in good used condition - £60 or £50 plus standard heelplates.
998FE Single Seat Unit (Red with Italian Flag and Campione Del Mondo Superbike text) in excellent condition - £350 or £250 plus standard biposto unit and seat pads (red).
Tecnosel Seat Pad in very good condition - £150
Carbon Hugger and Chain Guard in good used condition (Ducati Performace) - £150
Brembo P4Calipers, with pads and lines in excellent condition - £275 or £190 plusstandard calipers/pads/lines.
Renthal Quick Release Rear Sprocket Carrier in excellent condition (stops cush drive fouling hub) - £70.
Ducati Performance Carbon Fuel Cap (lockable) in excellent condition - £40 plus standard fuel cap
FIM Dual Injector Chip (cures hesitation/stutter) - £70
Picures to follow, if anyone would like any in particular just let me know.
Thanks
Old 17-Jun-2013, 12:52
Don't forget the Ohlins forks use a different bottom Yoke to the standard Showas
Old 17-Jun-2013, 13:31
kanerdog1x1's Avatar
kanerdog1x1 kanerdog1x1 is offline
Bikes: 2000 748 sp
Hey, v interested in the forks. Can you send pics? kanerdog1x1@yahoo.co.uk
Kind regards, Matt.
ooops, meant to say it comes with the bottom yoke which has been powdercoated black.
Ta very much
Old 17-Jun-2013, 13:34
Kind regards, Matt.
Matt, will get some to you within the next hour hopefully when my phones got signal!
Old 17-Jun-2013, 14:36
Bikes: 2000 748 sp
Hey, just got the pics. You got me all excited then, but I was after the version with the six bolt mounting for the caliper mounts as I want to run 108mm radial.
Sorry.
Old 17-Jun-2013, 15:00
No problem Mat, out of interest what model no is the forks with 6 bolt mounts.
Sorry.
Old 17-Jun-2013, 15:35
Bikes: 2000 748 sp
It's the same model number, fg320? I think.
Old 17-Jun-2013, 18:20
Sorry.
Not so easy to get the mounting plates for 108mm calipers as some of the Ducati ones came with plates for Axial mounted calipers usually 65mm and the others with Radial mounts for 100mm Calipers, took me ages to get hold of a set of 108mm adapter plates to fit my AP calipers, ended up buying a set of Ohlins R&T forks for a Yamaha R1 just to pinch the 108mm adapters
Old 17-Jun-2013, 18:44
Bikes: 2000 748 sp
Would be lovely to get a pair ready, but tbh wouldn't be too difficult to get some made. Just need the correct 6bolt bottoms.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:13.
