Old 25-Aug-2004, 15:13   #1
smilo006 smilo006 is offline
smilo006's Avatar
Mood: I like my bike
temp gauge
The needle has started to dance about like a Thunderbird puppet. Is it 80c or 120c. Before operating on it, is it likely to be repairable.
If not anyone got one they want to sell.
Most of the clocks on ebay are complete sets.
Old 25-Aug-2004, 15:22   #2
Steve Steve is offline
Check It's not the temperature sender unit, I had a problem insofar the needle didn't move, just changed the sender unit
Old 25-Aug-2004, 21:52   #3
Wildcard Wildcard is offline
I also have problem with my gauge. It does not move.. When u say the sender unit, do u mean the one connected to the cooling water? I`ve tried to change it, but it didn`t help..
Old 25-Aug-2004, 22:43   #4
Mark853 Mark853 is offline
Mood: The medication helps!
gauge!!!!!
It sounds like the gauge smilo006.
I had the same problem on my 748/853. Fitted 4 gauges all went tits up so i gave up in the end.
JHP did suggest the engine could have been out of ballance causing the gauges to bust.
Sold it and bought an R1.
Old 26-Aug-2004, 17:30   #5
Wildcard
There is a check you can do it tells you how to do it in the Haynes Manual. The sender unit I replaced is the bit ! that goes into the engine nothing to do with the gauge itself - sorry if i can't be more helpful but I'm not too technically minded
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:41.
