Old 01-Sep-2004, 21:38   #1
oil capacity
just changed oil and filter on my sps ahead of TA3, and following haynes manual put in 4l of premium oil. However, what came out was less (some burns off I know) but the oil window is completely full, like its over filled. Have I cocked up? If so, do I need to do anytiing or will it sort itself out?
Also, fitted a filter which I had for the 748 - just thought, they are the same, arent they???
Cheers,
Old 01-Sep-2004, 21:49   #2
Is it on its wheels or on the paddock stand when you are checking the level?
Old 01-Sep-2004, 21:57   #3
rapidomoto rapidomoto is offline
Hi Bradders, Have you let it run for a few minutes? Changed the oil on my 748 the other day, 4 litres in and when bike held vertical oil is at correct level. Oil does collect in various pockets round the engine which might lead you to believe you have initially over filled it.
Old 01-Sep-2004, 23:51   #4
paddock stand - but it was before the change and the indicator was in the middle. I have run it on tickover for anout 10 mins and then some neighbour annoying revving (!!)...see what its like at the weekend.
cheers
Old 02-Sep-2004, 00:02   #5
I think it should be on its wheels to get the correct level. Go by the lines, not by the amount you put in.
Old 02-Sep-2004, 00:03   #6
what if its overfilled - do I need to get some out? if so, how??
Old 02-Sep-2004, 00:06   #7
There's a smaller drain plug just above the oil screen.
Unscrew this (it's about 6mm allen key I think) and drain some oil out that way.
Old 02-Sep-2004, 00:07   #8
It's next to the sump plug. Piccy here:
http://ducatisportingclub.com/xmb/vi...14&pid=853 37
Old 02-Sep-2004, 02:01   #9
Mr_S Mr_S is offline
Bradders,
Have you got the oil filter removal tool? If so how pricey was it.
I Changed my oil & filter last week after Silverstone, and the filter was a swine to get out with a strap wrench.
Nearly reverted to bashing screwdriver through it
Old 02-Sep-2004, 09:48   #10
Bikes: ST4S
keith_mann1959's Avatar
4 litres seems half a litre too much. Just draining it would not get out whats in the oil cooler either.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:24.
