Old 02-Sep-2004, 22:14   #1
DaveDuc DaveDuc is offline
Mood: Sweet!!
02 900 Ohlins set up.
Guys,
Help required...........
After an enforced absence of 5 months I'm back on a Duke!
The 70 odd mile ride back yesterday left me grinning like a cheshire cat - I now remember what I've been missing!!!
Does anyone know what the standard factory settings are on the Ohlins shock?
BTW the guy had set the back up real funny - i.e. rear compression damping = 0, and rebound = 0..........., front comp and rebound = full !
Made for an interesting test ride..........
Dave.
Old 02-Sep-2004, 23:26   #2
tont2002 tont2002 is offline
Mood: waiting til next summer ;)
If you have the hand book it tells you the standard settings in there. :P
Shock absorber adjusters (900)
The Öhlins shock absorber fitted to the 900 model
features also length adjustment. It allows to adjust the
seat height regardless the spring preload.
• Compression damping adjuster (1):
14 clicks.
• Rebound damping adjuster (2):
10 clicks.
Undo lock nut (3) and nut (4) to change original setting.
STANDARD spring length:
160 mm
This is taken from the manual.
There's a few downloadable manuals on the ducati site:- http://www.ducati.com/bikes/manuals.jhtml
Hope that helps mate. I can always swop ya a perfectly set-up showa.
Steve
[Edited on 2-9-2004 by tont2002]
Old 02-Sep-2004, 23:43   #3
Mood: Sweet!!
Tont,
All I've got in the handbook is basically where the adjusters are - not much help - it does show hoever the range of adjustment ie 10 clicks so I'll try middling them out and see how I go......
Ta.
Dave
Old 03-Sep-2004, 00:06   #4
soz mate was re-editing that as you replied. took a bit to find it.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:24.
