Old 08-Sep-2004, 14:43
L3OONY L3OONY is offline
Mood: Mildly reckless...
Getting the wheels out... what do I need?
Need to get the front & rear wheel out to change the tyre.
Have I got a socket big enough? Have I bu88ery!
Can someone tell me what size(s) I need to be able to get the wheel out and also the sprocket carrier etc?
Need a front stand - any recommendations?
Also, the little clips on the rear wheel bolts have been lock-wired on by the dealer. Is this necessary?
Thanks
Old 08-Sep-2004, 14:58
moto748 moto748 is offline
46mm for the rear wheel. Go to Halfords and buy a 1 13/16" ball-joint socket. But most of all you'll need a foook-off great breaker bar!
And 41mm for the other side (sprocket side).
Someone will be along shortly to tel you the front size. I can't remember for sure, I think it's 28mm. It's a bit of an odd size, anyway.
Old 08-Sep-2004, 15:07
Yes, 28mm for the front which is a very odd size. I kept an eye out whenever going past DIY type places and managed to pick one up for 3 quid. Same with the 41mm and 46mm - 7 quid each from a local car place.
Old 08-Sep-2004, 15:08
748mart 748mart is offline
yes 28mm on the front.
Old 08-Sep-2004, 15:24
Don't forget you will need to unbolt the front calipers to remove the wheel, I think they are 8mm (or maybe 10mm) allen type & best to use socket type instead of key so you can torque correctly.
Be carefull when tightening front wheel nut as Antonye discovered this will split in half if overtightened.
Old 08-Sep-2004, 16:00
Cheers guys, am now off to find the necessary sockets...
One set of skinned knuckles coming up
Old 08-Sep-2004, 16:09
As Martin says, the 28mm nut is only used to draw the axle through the fork legs into the right place. The fork pinch bolts (the smaller ones) are then used to hold the axle tight. So don't overtighten it!
Old 08-Sep-2004, 16:14
rcgbob44's Avatar
rcgbob44 rcgbob44 is offline
I fitted a TI front wheel nut, so if you spklit the front one I have a spare front nut.
ps Don`t bother with the correct sockets, just get a 4` set of stillsons!
Old 08-Sep-2004, 16:25
This was a couple of years ago before I knew any better than to trust the Haynes Book Of Lies [TM].
Anyway, it was a good excuse to buy an alu one from TecMoto
Old 08-Sep-2004, 16:35
Have just invested in a set of shiny titanium ones from Casoli, and need some new tyres, so double the reason to get the bolts off!
Currently got some of the lads turning the workshop and Bodyshop over to see if we have any of these sockets, 'cus otherwise my £90 titanium nuts are going to get a little more expensive!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:43.
