Old 01-Dec-2013, 22:30
pguenet pguenet is offline
FS - breaking highly tuned 998 s engine (1038cc, race rods, etc)
Hi
I am breaking my 998 engine which was highly tuned by Chris at CJS Racing.
1038cc kit
102mm bore, Pistal High Comp pistons, Tuned heads with 42mm inlet valves, 749R cams (incl specific rockers)
Full gas flow done. Champion race spark plugs. This has had a dyno session and couple of track days on it.
Looking for £1400 with the 749R cams / rockers / modified shims
£1,000 without those
Sand cast 998 s cases
Pair of 998 s sand cast cases - those are pretty rare as not many Stretta engine had sandcast cases.
Deep sump obviously
£800
Lightened crank
standard crank lightened - JHP engraving on it
£350
Pair of Ti Race rods
Pankl RS race rods in Titanium.
They come with the shells that were in use
Not sure how many times the stretch bolts have been tightened.
£1,000
RS side generator case
Dual pick up, include mil spec pick up sensors
£400
749 RS flywheel + special spacer
Same as 998 / 999 RS set up to use a starter motor.
POA
Others items available:
Various gearing (primary, timing, etc), lay-shaft, sprocket,
Old 01-Dec-2013, 22:33
Old 01-Dec-2013, 22:41
Old 01-Dec-2013, 22:48
Old 01-Dec-2013, 22:51
Old 16-Mar-2014, 08:35
Last call on this - I have an offer of £1000 for the whole of the 1038 kit
Barrels / Pistons / Heads / Valves / 749R cams / etc.
Please let me know if interested and offering more than that.
thanks
p
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:40.
