Old 15-Dec-2004, 14:08   #1
mike916 mike916 is offline
Mood: Neutral - but only maybe. 1994 Duc 916S1, 2006 Duc Sportclassic 1000 Sport
Removing frame plugs
Does anyone know an easy way to remove frame plugs without damaging frame paint?
I fitted a set of ally plugs with rubber oil seal type securing rings to my 916 two years ago. When fitting these I has to grease up the plugs with silicone lube and it still took a lot of persuading with a rubber mallet to get them to seat properly.
Now I need to get them out to remove my engine/swingarm and have a bit of a problem. Is there an easy way to remove them without trying to pry them loose with a screwdriver which will damage the frame paint or is the only way to drill/cut/generally destroy the plugs to get them out
Any ideas welcome
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:47.
