Old 10-Jan-2005, 18:03   #1
There's a small white connector plugged into the back of the solenoid. Check this is pushed in fully, even give it a wiggle. It's a common problem. If the connections aren't good, the supply voltage to the solenoid coil is either none existant or not enough to pull it in hard enough to get the starter supply high enough.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:44.
