Old 16-Feb-2005, 23:56   #6
timetrial timetrial is offline
the way I find easiest is as follows:
Undo the lower rear fastener ( next to your footpeg) on the RHS of the bike first then the one underneath at the front that connects the RH fairing to the left. Next undo the fastener right at the front by the nose cone. Then stand side on to the bike and undo both dzeus fasteners at the same time and carefully lift off. You then need to pull the fairing towards you like opening a door to release the clip at the front - it takes a fair pull but it will come away no problems. Then repeat for t'other side.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:37.
