Old 18-Feb-2005, 09:30   #2
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
If it's carbon with good epoxy resin, the only thing it will do when you get it very hot is burn. That said, it depends if it was laminated with the correct, high temp resin, appropriate to the application intended for the part. I'm sure one of the experts will be along later.
Done right, it should be permanently rigid and you should not be able to reform with heat.
Rgds, Rob
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:38.
