Old 23-Feb-2005, 18:15   #8
revdecal revdecal is offline
Mood: Busy, Busy...Busy!
ive just fitted the engine bolt mounted kit. The engine bolt is replaced and a cast metal unit then bolts onto that and around a portion of the trellis frame.
The crash bung then bolts throught the fairing into that metal unit.
Always used them, and they have saved me a fortune in the past.
only gripe is the metal insert which sits in the engine bolt insert was 10mm too long, and i had to whip it off with a grinder to get it to fit!
not good when you pay £150 for it!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:01.
