Old 25-Mar-2005, 10:51   #5
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
On the wheel end, if the drive is too close to the fork to get a set of grips to the knurled ally, slacken the wheel spindle a couple of turns. That'll allow the speedo drive to rotate (the axle acts as a big pinch bolt). Once you've rotated it slightly, you should be able to grip it OK.
Hope this makes sense and helps.
Rgds, Rob
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:56.
