Old 29-Mar-2005, 14:47   #12
dickieducati's Avatar
Originally posted by TP
Originally posted by dickieducati
dont worry, reason for clearance issue has been identified and will be sorted.....anyone got the dialing code for sweden?
Ohlins anyone
What were you grinding BTW?
bellypan, both exhausts where the brackets connect the 2 bits of pipes just below the rearsets. wasnt doing it at rockingham but was taking it easier, hopefully turning quicker, and had probably ground away most of it anyway!
oh yes, sonic.......brands hatch..........
pretty much as tony said really if you dont have a track guide i could copy mine and post it to you if you think that would be of help. if you havnt seen one it gives you ideal line/braking points/turn in points etc. every rider is different but gives you a good idea of where you should be.
[Edited on 29-3-2005 by dickieducati]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:09.
