Old 02-Apr-2005, 22:58   #1
the phantom pieman's Avatar
Fork dive
Had my first trip of the year on my 998S. Cycle cat bar risers have made a huge difference ....
However , after not really riding it that much last year, I was reminded of another "issue". (please note other bikes are GS ADV and a Buell M2).
When you hit the front brakes, and perhaps because they are so effective, the front of the bike dives ... to the point where it feels un-nerving.
I'm heavy ... 125 kgs, and preload is wound in ... Does anyone have any good suggestions re set-up. In theory the bike was set up re rebound and compression when I bought it from Forza italia.
It sort of ****es me off ... or do I just have to get used to it again. Or is the issue really that the brake feel is a little wooden ( to me it allways feels like they are an on/off switch)
[Edited on 2-4-2005 by the phantom pieman]
Old 03-Apr-2005, 01:16   #2
Mr_S Mr_S is offline
Preload's not the thing to play with here, try increasing compression damping, and if you have that at max and it still dives too much for you try a heavier oil.
Strange that you notice the dive, as to me the 748/9** chassis dives less than any other.
[Edited on 3-4-2005 by Mr_S]
Old 03-Apr-2005, 13:35   #3
I'd go along with the advice from Mr S.
The preload won't cure the problem. Use the preload, front and rear, to set the sag up. You want the bike to settle about 25mm (ballpark) when you sit on it.
Turn the compression damping up to lessen the dive. It's the one in the bottom of the forks.
If my maths is right, at 125kg, you may need to have the forks and probably the shock resprung and revalved to get the best out of the bike.
Give K-tech (01530 810625) or Kais (01942 896366) a call.
Old 03-Apr-2005, 14:41   #4
Thanks ...
Will give compression damping a go ....
Old 03-Apr-2005, 17:12   #5
Totto Totto is offline
Have a read here http://www.gostar-racing.com/informa...ion_set-up.htm , you will prob need harder springs !
Old 03-Apr-2005, 20:52   #6
rcgbob44's Avatar
Pieman
How about posting a few piccs of your cycle cat bars, I would be interested as I`m thinking of fitting some to my 998.
Old 03-Apr-2005, 21:28   #7
Originally posted by rcgbob44
Pieman
will tomorrow be ok ?
Can be arsed to walk the 7 flights of stairs down to the garage ....
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:35.
