Old 07-Apr-2005, 23:21   #6
888heaven 888heaven is offline
Mood: UKGS'ers Non PC and Vibrant
bottom race
Mad Dog
Just removed the bearings off my T8 the bottom inner race I removed with a dremel with the little cutting disc attatchment cut through as far as possible without touching the yoke.
then with a small sharp chisel place in the groove and tap with one hard blow this splits the shell and it then pulls free.
make sure you have the yoke on flat but shock absorbing surface I used a bit of hardboard on the metal work bench.
hope this helps
ian
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:56.
