Old 11-Apr-2005, 18:29   #4
BDG BDG is offline
BDG's Avatar
Spinoli, i sympathise with you as i've had this problem and i'm a techno idiot
My basic idiots guide is make sure the picture you want to post is less than 1 meg or the board will not accept it. Also if the pixel size is too large same will happen. I normally resize the pics to around 800 x 533 pixels so they post OK.
Presumably the pix you wish to post will be located in 'My pictures' or 'My documents' on your PC.
When you go to do a new post there is a field at the very bottom marked 'attachment' and within that thee is the 'browse' field. Select browse, this will enable you to look in the relevant section (my Pictures) on your PC where you have got the photos, select the photo you want and the title will appear in the browse field then post reply.
Hey presto your picture should as if by magic appear on the board.
However if you are anything like me, nowt will happen, you will smash your PC in a fit of rage, wake the kids up, kick the cat....and hope someone with a bit if knowledge pops up.
Hope that helps but you're probably far better of listening to Dibble, except hes got such an annoying southern accent and therefore cannot be understood properly.
Gud job typing on computa's does unt reveal any accent man.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:16.
