Old 22-Apr-2005, 16:18   #1
small boy small boy is offline
Replacing neutral switch ?
Hi,i have stripped off the pipes to get at the neutral switch,what type of tool do you use to remove it as i cannot get a spanner on it,and the wires won,t allow a socket ,help ?
Old 22-Apr-2005, 17:12   #2
Derek Derek is offline
Bikes: ST4s ABS
Derek's Avatar
Use the right size of tube spanner with the wires up the middle. Turn the tube spanner with an ordinary spanner on the other end.
Old 22-Apr-2005, 18:05   #3
Lee Lee is offline
Lee's Avatar
I just cut a slot in a cheap ring spanner (leaving a sort of horse shoe shape) so as to slip it over the wires - worked a treat for me
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:49.
