General Motorcycles only
Old 16-May-2005, 20:56   #3
Gizmo Gizmo is offline
Mood: is it the weekend yet??
Originally posted by Green1
Has anyone used a certain product or knows a good solution to repair carbon fibre panels, as I noticed on one of the mounts has a small hole/crack in the side.
Thanks
I use carbon sheet and expoxy for repairing my sailing skiff. Its same as fibreglass, mix epoxy, brush over underside of whatever you want to repair put carbon on, brush more epoxy into it then get rid of excess, you cannot use it on the outside and expect to get a repair that is anywhere like the original finish which is usually vacuum formed. try an line marine shop like LDC Sailboats or Purple Marine . I've fixed cracks or stone chips on underside of huggers using that method. Small surface scratches can be polished out ith 2000 grade wet and dry then a lot of polishing.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:07.
