Old 20-May-2005, 11:38   #13
Gizmo Gizmo is offline
Mood: is it the weekend yet??
Originally posted by HW
Any use to you?
http://www.section8superbike.com/749-999suspension.htm
yeah i read that and used it as a guide for ride height although quite why they say lower front when you can steepen head angle i'm not sure. Dropping forks through does make a hugh difference though. I'm always reluctant to accept preload and damping settings, i tend to ride on bumpy roads not a race track so need a more comfortable setting which is usually softer and with little rebound to stop it packing down as you go through a series of different size bumps.
The Ohlins website has some useful stuff.
The following pdf's cover most of it
Ohlins fork manual
Ohlins rear shock
Set up guide
Ohlins tuning
[Edited on 20-5-2005 by Gizmo]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:14.
