Old 25-May-2005, 00:09   #1
ali ali is offline
ali's Avatar
Mood: Damp
Several ways of skinning the same cat.... I use a straight edge to the swingarm pivot and score a couple of marks where the centre of the rear wheel spindle is. It's not perfectly accurate, but it's not that important as my frame is bent as a nine-bob note.....
Ian's method of using two bloody great straight edges all the way to the front wheel is generally though tof as the best way. I saw one of the BSB teams using this method at Brands on Good Friday so it's probably good enough for DD!
Ali
ps: If you use the torque wrench for when you're bolting into super-soft alloy crankcases, and not when doing up bloody great wheel spindles, you'll probably end up with less stripped threads......
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:24.
