Old 28-May-2005, 08:51   #1
M600 Forks
So then, which forks will fit a 1994 M600 without needing any mods? I'm looking at a set off an M900 but they dont appear to have the mudguard brackets on them like the 600 has.
Old 28-May-2005, 22:38   #2
The Monster forks changed in my2001(I think?).The mudguard brackets are the same as the Superbikes/SS's and St's,.....ie they are plastic brackets that clip around the fork bottoms.The '01< mudguards are slightly longer to suit.
Old 28-May-2005, 23:18   #3
Cheers Keith. So if we go down that route we need a front guard as well then.
Old 30-May-2005, 08:31   #4
Yes mate.
Here's the '94-200 set up.
Old 30-May-2005, 08:32   #5
....and here's the '01 onwards front end.
Spot the differance?
Old 31-May-2005, 22:27   #6
Gary T. Gary T. is offline
Gary T.'s Avatar
Mood: dazed and confused
Note that the wheel spindle is larger diameter & hollow on later front end, where as earlier bikes have solid spindle. Also the caliper mounting bolt holes are further apart (different type of calipers used) Hope that helps?
[Edited on 31-5-2005 by Gary T.]
Old 31-May-2005, 23:05   #7
That was my next question! So i basically need a whole 900 front end, both forks, caliper, spindle and if the spindle is bigger won't i need the wheel as well?
Old 31-May-2005, 23:16   #8
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
No, just a change of wheel bearings should do it Paul.
Old 01-Jun-2005, 09:34   #9
Cheers Andy.
I think the pattern fork tube that Nelly has ordererd is going to be the easier option.
There are a pair of M900 forks on ebay at the moment for not much money but i know Monsters have a habit of popping the left hand seal so they might not be any better than the ones on the bike at the moment.
Old 01-Jun-2005, 17:52   #10
Jamcoly Jamcoly is offline
Jamcoly's Avatar
Mood: starting to feel better
left hand fork seal?
I've done the right twice within a year
never done the left
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:49.
