Old 05-Aug-2003, 10:43   #1
biker14 biker14 is offline
Mood: Want some knee down action
Rev limiter too low?
Hi all,
I have a 02 998S with 3.000kms, and I noticed that it is cutting off when the rpm gets to 10.000?? . I find it a bit low, but ok, I am coming from a 4 Cylinder japonese...
So question is, is this normal, or when they did my first service they forgot to remove this?
Thanks
PC
Old 05-Aug-2003, 11:05   #2
DJ Tera DJ Tera is offline
998s should rev to at least 10.500 -11K
Old 05-Aug-2003, 12:32   #3
BOLT BOLT is offline
Mood: Waiting for the Sunshine
mines a std 998 and rev-limiter cuts in at 11,000 rpm - often !
Old 05-Aug-2003, 12:41   #4
BTW the ducati tacho is about as accurate as a fake rolex - i use my revlight as it is far more accurate!
Mine cuts at 10.5
Old 05-Aug-2003, 13:33   #5
swiss 998s swiss 998s is offline
My 998S limiter cuts in at 10.5 as per the dyno. Are you sure you are reading it right, pretty hard to tell the difference btwn 10 and 10.5 when riding hard at the limiter.
Prefer to ride mine 6-9k anyway and ride the torque.
PS do you have a flat spot at 4.5 - 5k?
Old 05-Aug-2003, 16:44   #6
Rev limiter and flat spot
You are probably right, it is a little bit difficult to tell the diference between 10k and 10,5k, especially when you are overtaking a friend's GSXR600 over 200 kms as if they are stopped
And as for the flat spot, I do notice it also, but I try to keep it as much as I can above 6.000 rpm... I am thinking of upgrading to a 54mm half system, which should probably even make it worse, but I can only dream of the sound and the top end rush
thanks for all the replys
Paulo
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:23.
