Old 17-Jun-2005, 18:49   #8
The place I use in Oxford sells Castrol in different grades, you can add some more to increase the effect of the air-spring but it can make your seal go easier. If the air gap is less then as the forks compress the pressure builds at a faster rate.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:31.
