Old 13-Jul-2005, 10:24   #20
Originally posted by Gizmo
Originally posted by andyb
Although my bike is an 03 i fitted the full 57mm termi system. The problem is doing the quiet t/days as with the assymetric system you can swap cans but this you cant.
So, ive aquired a second std can and modified its end to accept the full 57mm pipework! Woo hoo.............
I'd thought about getting this done. Did you have a new final "Y" piece made? if so who did it please?
No ive left the final y piece as is. If you line the std can next to the termi one for the 57mm, you can see the std assymetric one is longer. I cut straight across to make it the same length as the termi, you can if you cut carefully, modify the pieces of pipe youve cut off as the new flanges.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:50.
