Old 13-Jul-2005, 13:52   #21
gimpboy450 gimpboy450 is offline
gimpboy450's Avatar
Mood: crank it and bank it
Thanks twinfans
Old 13-Jul-2005, 18:13   #22
Gizmo Gizmo is offline
Mood: is it the weekend yet??
Originally posted by andyb
No ive left the final y piece as is. If you line the std can next to the termi one for the 57mm, you can see the std assymetric one is longer. I cut straight across to make it the same length as the termi, you can if you cut carefully, modify the pieces of pipe youve cut off as the new flanges.
sounds complicated don't suppose you have photos??, take it you just used silicone exhaust sealant to fill it all in??
Old 13-Jul-2005, 20:04   #23
Silicone what????? wash your mouth out young man!
Ill do a photo or two.........
Old 13-Jul-2005, 20:14   #24
std can with modified rear to accept the 57mm 'Y' piece.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:14.
