Old 25-Jul-2005, 01:17   #11
chillo chillo is offline
chillo's Avatar
i've suffered with this!! didn't put a hole in it but ground it away nicely!
had mine replaced with a beefier one machined from billet alu! no probs since!
just keep an eye on it.
2 mates have had the same, changed to the beefier billet version and all ok now! (one did hole his, but i saw him deck the plug out and told him to stop. Which was a good job as it spilled its guts right there within about 2 minutes! )
Will find out the possibilty of my mate getting some machined, he may punt a few on if anyone is interested. I will get a pic of one.
Old 25-Jul-2005, 12:42   #12
Gareth Gareth is offline
I've got a 2005 Mono. I have not experienced this problem, but might have to check the bottom of the bike ! Living in the South it is reasonable that I have not experienced it, but I am off to France in September and we don't use motorways so might run into the problem, especially on the more minor roads in the SOF.
What I would question is why is it happening on the 2005 model and not the 2004 model. The engine is the same...as far as I know... shock is the same but the swing arm is different, is the ride height lower due to the swing arm?
Old 25-Jul-2005, 12:54   #13
I have a deep sump testastretta engine in my 998R and was a bit curious about this.
What bikes are the damages limited to? Only 05 model's? Earlier model's?
Old 25-Jul-2005, 14:57   #14
Real McCoy Real McCoy is offline
Year doesnt matter, Its just the deep sump R & S models
Old 25-Jul-2005, 15:26   #15
Surely this has got to be setup problems then, whether that be ride height, forks through the yokes or sag/compression, spring rate etc?
The 05 models come with a heavier spring so I would of thought this would of been less of an issue.
I only run with TD kit on and my belly pan is a sealed unit, not even a mark on that fom various track days ( Brands down at the bottom of paddock hill would be good test of compression) and various twisty undulating roads (Cat and Fiddle etc)
Old 25-Jul-2005, 18:07   #16
I think its more wheelies and air born jumps etc, These arnt just isolated instances surely a sumplug mod is all thats needed.
The thing is people make it sound like weve done something wrong, if that was the case im sure Ducati would have pointed it out rather than repair the bikes
Old 25-Jul-2005, 19:35   #17
itexuk itexuk is offline
itexuk's Avatar
Mood: Great
A naked 999 ( Special)
http://www.ducatisportingclub.com/xm...5&pid=211 835
[Edited on 25-7-2005 by itexuk]
Old 25-Jul-2005, 21:44   #18
pedro pedro is offline
pedro's Avatar
Mood: r
Originally posted by andyb
Im sorry but how do you smash your sump on a road?
Old 31-Jul-2005, 23:59   #19
bike mad bike mad is offline
bike mad's Avatar
thanks for the heads up, I've just checked my bike, theres cratches on the sump and fairing, not so good on a bike thats not even run in yet, guess I'll have to stiffen the front up and increase the ride hight at the rear,
cant see any other way to stop it, ps mines 2004
Old 05-Aug-2005, 23:27   #20
BAD LAD BAD LAD is offline
05 999 HAS 03/04 S DEEP SUMP ENGINE
SEAMS THIS CAN GROUND OUT OVER JUMPS/UNLIKEY TO GROUND OUT ON CORNERS
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:14.
