Old 04-Aug-2005, 18:56   #29
Guido's Avatar
Originally posted by marksduc748
can you tell us any more such as:
is the rear wheel spining free when in gear??
was you riding it when it happened??
is it hard to find any gear?? running or not.
not good running it till you find the problem although now youve dropped the oil you wont be. hope all goes well and there’s light at the end of the tunnel.
I would start with the clutch
Full story is as;
Did Cadders track day - no noticeable problems at all with clutch or gears. Took bike home and dumped it in the garage.
Following Sunday replaced all road items such as indy's, lights/number place etc and road bodywork. Got wifey on the back and set off on an 80 mile jaunt.
Within ten miles I noticed after changing gear (at this point didn't know which one) as I opened the throttle, the bike lurched violently off and on (in a kangaroo stylee as if you had a fuel blockage etc). It eased as I opened the throttle more, disappearing completely over about 5-7k rpm. I thought it was strange but carried on as all seemed ok.
As I went through the gears after leaving lights/roundabouts etc, I noticed it did the same again disappearing as the throttle was opened more (it only happened straight after clutch lever was released and the throttle opened after changing gear). When we stopped for an ice cream, I checked the back wheel, chain and sprockets thinking one of these might have come loose after the Cadwell thrap and a year of the bike sitting idle. Nothing untoward was found here.
We set off on the final leg of our day with the lurching on a particular gear change continuing. I started to monitor it and found it was 4th gear that was giving the problems. On the upchange from 3rd I got the lurching as the throttle was opened. This kept disappearing as the power was fed in enabling me to achieve the normal 10krpm-11krpm gear change into 5th and 6th. if appropriate.
When I got home I again checked the chain/sprockets for piece of mind despite knowing it couldn’t be this if it was only in one gear where the probs were being experienced.
The bike was put away for the night leaving me perplexed. I took it to work the next morning checking things along the way. Same symptoms continued. I also noticed finding neutral upon stopping was more awkward than normal (i.e. down to bottom and one ‘snick’ up normally does it). Took me a few attempts to get the green ‘N’ light on. After work I met one of the lads who rebuilt my engine. He was unsure it was the box as of course the bike didn’t make the crunching noise when I started it for him in the garage and went thru the gears. He suggested topping up the oil to ensure the box was getting enough lube as it was a little lower than normal. We then greased and adjusted the rearset and gear change mech on the bike before he said to take it out for a run. I went out for 30 minutes and during this time found that the bike would not pull through 4th at all now. The lurching and crunching remained despite engine revs or throttle position. Gears 1-3 were fine and 5th & 6th also were fine.
I returned home extremely despondent looking at another year without the bike knowing it would entail a “motor-out” exercise if and when I could afford it..
That’s bang (literally) up to date.
Gc
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:50.
