Old 08-Aug-2005, 12:31   #3
Derek Derek is offline
Bikes: ST4s ABS
Derek's Avatar
Check the bearing in the pressure plate. That could be causing the squeek and may also be the cause of clutch drag. If it is seizing it will cause the pushrod to spin with the clutch, which will in turn spin the slave cylinder piston, then the seals will go.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:34.
