Old 28-Aug-2005, 13:08   #5
Agree with Rich. The cooling efficiency is improved by the anti freeze as is the anti corrosion properties.
I only use 50/50 anti feeze/distilled water in the cooling system. Best combination of all the properties available.
The corrsion problem can be a problem. There's a mechanical seal behind the pump impellor and as the corrsion builds, and it does at an alarming rate, it'll eat away at the seal. When it goes, the coolant goes straight into the engine...........
If you're thinkin of water only for track use, then use distilled water and flush the system regularly. I wouldn't bother at all for the road.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:09.
