Old 30-Aug-2005, 22:18   #18
Originally posted by pacegod
Ive got a 748r and put a ti STM on, which i found to be a nightmare. The bike would either stall or you had to rev so much the bike would shake and shudder. My brother also had one on his 748s which did exactly the same but not quite as bad.
I now have a 4 post corse clutch from niki748 off ebay, which is a revalation.
Does exactly what it should do and is really light at the lever. I know it works by ramps and not bearings, but so long as i look after it, it will be fine.
Id go for the ones off ebay, as they are good value, my plates are nearly new, and the basket has no wear.
I think if it has a ramp it will have bearings running up and down the ramps.
Only the cheap tack like the original 748r had basic ramps!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:24.
