Old 08-Sep-2005, 14:48   #3
phil_h phil_h is offline
phil_h's Avatar
It is possible fit the chip one pin out of alignment - which _shouldnt_ blow it up.
Alternatively, 1 pin of the chip is bent or broken too short and not making contact.
If you want to send it to me I can check that its ok at work (electronics engineer) and poss still make a copy if its a broken pin.
I've run my 748 with 3 different chips and with different power commander maps with different chips.
If its too lean the performance goes off, and you will know that all is not right !
The engine will run (poorly to badly) with a lean mixture but because it also runs hotter, you really musnt run it lean for any length of time or your piston will let you know it doesnt like it
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:49.
