Old 09-Nov-2005, 00:05   #11
iang iang is offline
iang's Avatar
Yes, Thank you keefyB and Ace, Knew I was not going mad.
If the pipes fit the 999S they should also fit any other bike with the deep sump engine and new swinging arm, it will only be the ecu that would be of no use.
Usually the pipework can be bought separately so without the ecu it will not work out that expensive, cmon Martin do your homework :P
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:37.
