Old 28-Nov-2005, 15:40   #7
Originally posted by philthy
And if you're changing the sprockets you may as well check and replace the wheel bearings and cush drive at the same time, and does the rear wheel need powder coating/ or a new tyre? And if you are doing the back wheel you may as well do the front..............................
Sorry ...... I got carried away
Phil
I think youll find, only a fool would change just a chain in the case where your replacing because its worn, as the sprockets would be just as worn and bugger up the new chain within a thousand miles!
If your changing for looks or cosmetic then you could get away with a chain on its own. But as they come in certain oversize lengths, it is an opportunity to fit a larger rear sprocket, as most find this beneficial!
Unless your regularly on your sports tourer at 170mph?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:28.
