Old 02-Dec-2005, 13:16   #1
fil2 fil2 is offline
fil2's Avatar
Mood: is it still wet
Originally posted by skidlids
As I mentioned above I used 1.0kg/mm Ohlins springs destined for a Honda Firestorm.
I always use Ohlins fork springs and have used spring rates from 0.85kg/mm up to 1.0kg/mm.
Weight and riding style come into it as does front to rear weight bias and available fork travel. Then you also have preload and the air spring to play with
jesus............is that swaheeli to any1 else.???
u dont fancy showing me the ropes one day do you kev.?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:22.
