Old 16-Jan-2006, 13:45   #2
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
I have a set of very good condition 750ss forks available. Would you be interested in these? Twin disk compatible as well.
I'd be interested in your forks as a swap plus some adjust your way. Can you confirm the dimensions required at the upper/lower yokes together with the overall length from the bottom of the fork to the top where the caps screw in. Also, what spacing are the caliper mounting bolts? Mine are 65mm.
Cheers!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:32.
