Old 17-Jan-2006, 23:44   #14
Originally posted by phil_h
Hmm - I wonder if you can easily fit different ends to ohlins ?
I need a nice 330mm shock for the SS
Richard at Harris performance will modify Ohlins shocks, so you could get a fork end changed for e rod end or vice-versa. Also longer or shorter damper rods and be fittted.
Alternatively shocks which alread have a ride height adjuster fitted could no doubt have a extension bit added (bit like the ones we had for DT175MX's and similar principle to the jack up adapters for early monsters)
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:00.
