Old 27-May-2003, 10:41   #8
Yeah, it's the oil pressure switch. I had the exact same thing in the winter. It starts off by coming on at idle and going out again when you blip it, but after a while it'll start to get worse. Mine started flickering and then staying on solidly about 5-6miles into each ride. Since I knew I had enough oil, and knowing that if the oil pressure had been low it would've started to make expensive grinding noises after a few miles, I did a couple of hundred miles on it before Nelly replaced it at service time.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:31.
