Old 08-Feb-2006, 15:20   #11
loverobot's Avatar
Originally posted by nelly
Not aware of any trackdays stipulating water only, but......... If you are going to run water only, distilled or otherwise, drain and flush the system regularly.
It doesn't take long to start clogging the cooling system up, especially the rad.
The corrosion also eats away at the mechanical seal behind the pump impeller and then you'll be running water/oil in your cooling system
cheers nelly - will bear that in mind
btw i forgot about coming back about the 748 evo no plate hanger - are they still in stock? whats your contact number?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:08.
