Old 10-Feb-2006, 23:41   #11
andya andya is offline
andya's Avatar
Originally posted by aka.eric
I used a Scotchpad bought from paint factors,like a fine pan scourer.Removed the flakey paint,feathered the edges,masked up and a couple of coats of high temp paint.Engines been hot a few times since and it seems ok.
[Edited on 10-2-2006 by aka.eric]
Where did you find the high temp paint?
Old 11-Feb-2006, 00:05   #12
Twinfan Twinfan is offline
Twinfan's Avatar
Halfords? I got a spray can of the stuff for the exhausts on the missus' RS250...
[Edited on 11-2-2006 by Twinfan]
Old 11-Feb-2006, 11:46   #13
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Andy,
Good luck with the project. As I'm sure you can see, your amongst fellow addicts here. Why don't you keep a spread sheet on the costs. You'll be amazed how it all mounts up
Old 11-Feb-2006, 14:59   #14
andya's Avatar
Probably best if I dont keep a record. It doesnt seem so bad when you buy lots of things on separate occaisions, you can kid yourself
its costing less than it really is!
Or kid the wife!!
Old 11-Feb-2006, 16:26   #15
851neil 851neil is offline
Mood: need a bike...
mmm, DO NOT keep a spreadsheet - you'll only worry yourself, BUT DO keep all of the bills tucked away so you can frighten yourself when it's all done
Old 11-Feb-2006, 22:55   #16
Charlie Charlie is offline
Bikes: T8 SP4 / Buell 1125CR
Charlie's Avatar
Aluminium is a b#gger to clean once oxidization starts, I stripped my casing and bead blasted it, coat of spray paint and trimmed the gasket flanges with a Stanley blade while the paint was still soft.
Old 11-Feb-2006, 22:57   #17
Charlie's Avatar
When the missus was out shopping for the day I baked at 50c for an hour.
Old 13-Feb-2006, 23:58   #18
phil911 phil911 is offline
phil911's Avatar
Mood: Privileged ...
Did you previously remove the gaskets and glass window ???
Old 14-Feb-2006, 14:25   #19
Charlie's Avatar
Hi Phil, I never took the glass inspection window out the casing, i stripped out the Alt, etc. In the oven they never went very hot.. lol………..its freezing up here and I had to cure the paint!
Old 14-Feb-2006, 21:32   #20
phil911's Avatar
""""its freezing up here and I had to cure the paint! """"
---> OK !!!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:28.
