Old 15-Feb-2006, 13:49   #5
m1keyp m1keyp is offline
Hello and welcome.
I sincerely hope that it is not the same problem that I had.
At 4500 miles and thankfully under warranty my engine did as you described.
It turns out that a small grub screw in the crank had worked loose and machined itself to pieces destroying the big end bearing
Good luck as i said I hope that I am wrong, it is a know fault "which only happens rarely so Ducati have done nothing about it" to quote a Ducati mechanic
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:10.
