Old 25-Feb-2006, 12:16   #1
monstermob 998's Avatar
oil in air box?
just been to have a look at a carby SS 900 bit scruffy but that is reflected in the price- was keen to buy until i noticed oil on the inside of the fairing ( left hand side) there was no apparent oil leak on the engine - when i lifted the tank to peek in the air box there was a small pool of oil/water/petrol around the airbox drain!! this has obviously leaked onto the fairing causing the oil stain that i noticed on the inside of the fairing-
what would cause this blow back of oil and petrol into the airbox?????????
is it a case of blocked breather tubes or something a bit more serious???????
any suggestions?
Old 25-Feb-2006, 12:24   #2
Could be the rings/barrells worn giving a bit of blow by, causing part of the compression stroke to pressurise the crank cases.
What sort of money is it as I know of a couple of decent 900SS that may well be for sale in the sping
Old 25-Feb-2006, 12:27   #3
yorkie yorkie is offline
Bikes: 900 Monster, 750 SS Cafe Racer
yorkie's Avatar
Oil in the airbox may be from the crankcase breather through the crankcase oil boxes (Little plastic jobbies under the seat) and then into the airbox! If it has never been cleaned out then thats where that has come from!
As for the water is it a build up of condensation? Has it been kept out side? Has it got an open air box? All of these maybe causes!
As for the petrol is it just the seperation of oil/water mix, it will smell of petrol any how!
Hope this helps, im sure someone with a more technical mind will give you another reason/solution!
Yorkie.
If it was a bargain id clean it and observe!
Old 25-Feb-2006, 13:02   #4
kev -its up for 1200 -as i said its far from showroom condition was thinking of knocking him down to 1000 -it has got an ohlins on it tho needs new chain and sprockets and battery- a couple of months mot but no tax-15000 miles
yorkie-it has been kept outside- not even a cover over it- no open airbox -no smoke on start up- altho he said its stood for 4 months jump started from car battery 1/2 choke and fired first time!!
i'm going back with compression tester and a few other tools this afternoon
will keep u posted
Old 25-Feb-2006, 13:12   #5
At that price its probably worth going for it especially when you factor in the Ohlins and if it has reasonable compression.
Now that people like Jim at Bike Enders have things like 1000DS engines for sale as well as earlier engines you could do it up over a period of time and get a fair few years enjoyment and service from it
Old 25-Feb-2006, 19:21   #6
SSTU SSTU is offline
mm 998 where did you get your twin headlight fairing in your Avtar
Old 25-Feb-2006, 19:44   #7
philthy philthy is offline
philthy's Avatar
Mood: Can't make me mind up
Skidlids is probably right in his opinion on the problem. It sounds like the bike has not been looked after and may well turn out to be a money pit. This is the right place to find a tidy one. If I was you I would walk away and don't look back.
Old 27-Feb-2006, 16:04   #8
ive walked away- for nowlow compression on vertical cylinder only 5bar
U2U SStu
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:45.
