Old 27-Mar-2006, 11:44   #5
james81273 james81273 is offline
james81273's Avatar
Mood: twitching
Yep I went with Barry for the full set. Great guy and good work. yes you could paint the panels but I didn’t and just stuck them on The finish is great, need a bit more t cut on the side panels as they are ever so slightly a lighter red then the rest (tank, seat, nose) I mainly bought the body kit so it doesn’t matter if I drop it or cut it for some crash protectors.
There are three things you may need to do once you get it from Barry. (But normally, you would have to with any other aftermarket body kit)
1. The side panels need a little cutting so they fit smoothly around the radiator. No biggie and a Woolworths own "dremmel" for £14 did the job with no problems in seconds (don’t worry you wont see the cut marks after it’s on the bike)
2. Barry doesn’t have a 100% road top fairing when he did mine (last week). Instead he used a race one and cut the head lights out for me.
3. Daft to say but all the seat lights and brackets need to be taken off the old seat and place on the new one.
When it come to fitting the body work. I personally found it was best to work from the top down e.g. front top fairing then sides and then bottom. DONT FORGET to place a blanket on the ground around the bike to stop the pannels from being scratched as you fit them.
Only gripe= not enough vents...the bike does get pretty hot through traffic in summer so with these panels it may be a little worse.
For £300 ya mad not to use him. And he’s quick and professional.
Here’s the picture but it’s not great ill try and get some more tonight (am i going mad but does anyone else think I have the bloke out of the film scream on the side panel? must stop licking the bike!)
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:54.
