Old 14-Apr-2006, 20:28   #2
Fordie Fordie is offline
Regional Organiser - BHCN
Fordie's Avatar
Mood: Raring to Ride
Zhed, when you pulled the clutch apart did you check the pushrod , ive had one break before and that will give intermitent problem. The pushrod can stick if the bearing on the pressure plate is siezed then it spins the pushrod and knacker the slave cylinder seals although the brake fluid does turn dark soon after replacing it turning brown does'nt sound to healthy ,any signs of leakage at the slave. It may be a replacement slave cylinder needed 4D
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:41.
