Old 18-Apr-2006, 09:06   #4
paynep's Avatar
Mood: Wet wet wet
The 17 and 20mm spindles are interchangeable, as long as you change the threaded insert in the lefthand leg too.
So basically if you get forks that had a solid rather than hollow spindle you can keep your wheel, speedo drive etc.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:37.
