Old 20-Apr-2006, 09:26   #1
JD65 JD65 is offline
bleeding brakes
I had to undo the brake line on the front master cylinder and now everthing is attached again i cant get the system to bleed. the master cylinder is pumping the fluid through to the calipers i have pumped a whole 500ml bottle through and still the lever is coming back to the bar. and i cant see any air coming out.
I also tried bleeding from the top banjo bolt but that did not help eather. any ideas. is there an air pocket in the top of the master cylinder?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:56.
