Old 20-Apr-2006, 12:51   #6
Wylie1 Wylie1 is offline
Wylie1's Avatar
I had a similar problem after replacing the fluid in my clutch (air at/around lever). Initially, it was fine, but then the lever started coming further & further back to the bar.
There is a bleed valve in the reservoir itself (on the clutch side anyway!). Assuming there's one in the front brake reservoir as well, take cover off, then squeeze lever as you undo valve. Tighten valve as the lever gets close to the bar. Only took 3 squeezes & the clutch was perfect!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:56.
