Old 29-Apr-2006, 16:11   #1
zhed44 zhed44 is offline
zhed44's Avatar
Mood: YELLOW!!!
Shock Absorber: How Much? Recommendations Please
If I decide to look for eg: an Ohlins shock on eBay, what should I look out for? How much should I pay? Are they interchangable between all 9** and 748 models?
Usage - mainly road use, with occasional track days.
Thanks
[Edited on 29-4-2006 by zhed44]
Old 29-Apr-2006, 21:46   #2
aka.eric aka.eric is offline
Id recommend Maxton,a new units about £480,rebuilds obviously vary in price.Tried Ohlins but required a rebuild after 8 months,depends if your one of these label junkies
Old 29-Apr-2006, 22:11   #3
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
Hello zhed44
U2U sent
regards
TopiToo
Old 29-Apr-2006, 23:51   #4
zhed44's Avatar
Mood: YELLOW!!!
any recommendations for someone to do a rebuild? i don't think i really need an uprated shock as i mainly ride on the road and i'm not particularly quick. if it is fairly cost effective and the turnaround is quick, then i'll take the "rebuild" route. however, if i can get an uprated shock for the same price or less, then i'm tempted to get one.
thanks
Old 30-Apr-2006, 08:02   #5
Totto Totto is offline
http://www.k-tech.uk.com/
Good sound advice !
Old 30-Apr-2006, 16:20   #6
Set up Engineering in Wandsworth.
MH Racing in Wiltshire.
Maxton.
Any suspension specialist will rebuild a standard unit,its wether or not its cost effective if too many parts are required.Have a chat with them.A standard unit in good condition,set up correctly is perfectley adequate for road use and trackdays.With 99% of folks claiming to need "uprated" suspension,its a case of egos writing cheques that their ability cant cash.
Old 30-Apr-2006, 19:00   #7
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
That's a bit like owning a Ducati then....ego driving a the desire for a bike most are unable to ride to 5/10's.
Old 30-Apr-2006, 22:07   #8
zhed44's Avatar
Mood: YELLOW!!!
thanks for the advice and leads.
as i said above, i don't really need an uprated shock, but if i can get one for less than the cost of rebuilding the stock item, then purely for the sake of making the bike a bit more trick and therefore sellable, then i might get one. i'll give those companies a ring next week so i can weigh up the pros and cons.
obviously, if i do get an ohlins or similar, what model numbers should i look out for/avoid given that i'm a road biased rider? ie: i don't want something too track oriented.
thanks again
Old 30-Apr-2006, 23:37   #9
Maybe worth Giving Baines Racing a call, My mate had a 900SS off them a few years ago that had been reworked/overhauled and internal parts replaced with WP stuff.
Old 01-May-2006, 00:17   #10
DSC Member final_edition final_edition is offline
final_edition's Avatar
Mood: Having some tinnies and a barbie
I use these guy's. Top service and they know their onions.
http://www.hmracing.co.uk/default.asp
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:42.
