Old 11-May-2006, 20:54   #1
Col996s Col996s is offline
Bikes: 996S
Col996s's Avatar
Datatool Veto Evo
Today I went to use my bike and the alarm would not disarm with the keyfob. My spare one worked ok and so I used that. Anybody any experience of this? The LED lights when the buttons are pushed. The battery is good as I swapped it with the good one.
Any ideas?
Old 11-May-2006, 20:58   #2
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
Sounds like it need re-aligning.
Old 11-May-2006, 21:05   #3
Bikes: 996S
Col996s's Avatar
What does that involve Nick?
Old 11-May-2006, 21:18   #4
NBs996's Avatar
press both buttons at the same time for about 5 seconds (until it beeps).
Can't remember what state the alarm has to be in for this procedure... i think it's fully armed, but if that don't work try it disarmed with ignition on.
Otherwise I've got no other ideas.
Old 11-May-2006, 21:28   #5
Bikes: 996S
Col996s's Avatar
Thanks Nick.
That did the trick.
Old 12-May-2006, 07:54   #6
Ian Harris Ian Harris is offline
Ian Harris's Avatar
Col, I have the same problem with mine...what state did you have the alarm in when you did the "re-align"?
Thanks in advance to both Nick and Col
Old 12-May-2006, 08:13   #7
Bikes: 996S
Col996s's Avatar
It was in the armed state. I pressed both buttons together and the alarm did a double bleep within seconds. I then let it arm its self and then I was able to use the key fob as normal.
Good luck and thanks again Nick.
Old 12-May-2006, 08:20   #8
Ian Harris's Avatar
Many thanks!
Old 12-May-2006, 08:34   #9
weeveetwin's Avatar
Hi guys
You can download a user's guide here:
http://www.google.co.uk/url?sa=U&sta..._ug.pdf&e=9797
Old 12-May-2006, 08:37   #10
Bikes: 996S
Col996s's Avatar
Thanks.
What a wonderful club this is.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:38.
