Old 13-May-2006, 19:45   #11
Just fitted one to the 996, had to tweek it slightly with a pair of pliers but it is now in place and I will be out on the bike tomorrow,
I haven't tried fitting a sprocket cover as i don't run one on the 996,
Also I am running a 14T front sprocket and have loads of clearance so should be OK with a 15T, I will find out when I fit one to the 998 Hybrid in the next day or two.
At some time I will try and fit the sprocket cover as it looks as if it should fit OK once the bit of plastic protruding like a small shelf is cut off from the inside as the stainless protector comes around this far
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:59.
